CRG VEN-91 Brake Replacement
Information & Questions about karting in general.
Brian Kuempel
Post by Brian Kuempel »
Anyone know of a drop-in replacement caliper for the CRG VEN-91? I want to replace the front calipers but would rather not replace the spindle, hub or brake discs.
Or, if anyone has any laying around, I need the front left inner half and the front right outer half.
-Brian
Brian Kuempel
Re: CRG VEN-91 Brake Replacement
Bolt spacing between mounting holes is 62mm.
Distance from spindle mount to caliper centerline is approx 26mm.
Mounting bolt is 8mm.
The VEN-99 caliper looks like it may be close. If anyone has a set they could measure, it would be very helpful.
Thanks in advance.
